Sick Mondeo :(
23 Nov 2007
Lancashire, UK
My faithful steed is sick :(.
Went to head to work this morning and she won't start.
Turn the ignition on, front panel lights up ok, I hear the usual distant "whirr" (fuel pump??), and then silence. All normal.
If I turn to start, the starter turns the engine over, but fails to even start to catch. It does however, produce enough torque to push the car out of my garage as I raise the clutch, and also reverse it back in (failed attempts to give it gas and lift the clutch while starting).
I've hooked up a jumpstarter, with no change. I'm just hoping that the jumpstarter is in need of a charge (which is ongoing as we speak).
Any other suggestions for what might ail it? It's an 02 Mk3 petrol 2.0 LX. Plenty of fuel (filled up the other day), and had a good 50 mile run on its last trip, where it has then sat in the garage since Saturday night.
Thanks in advance, suggestions hugely appreciated!
I would be checking the coil packs, to see if there is a spark, have you any local friends etc that could scan the car for you.
If it was the coil pack surely he would notice miss fires for ages before it actually just dies?
check the fuel injector.. if fuel is being sprayed/inject.. check the fuse for the fuel pump too. That happened to my focus. The car would not start, would attempt to turn over then cut out. The fuse had blown, so fuel was not being injected into the engine.
SHE LIVES!!!!!
Have to see if I can have the same luck tomorrow. Ended up resetting the fuel system since the jumpstarter had no effect, and feathering the throttle to get the odd catch going, and finally the persistence paid off! Just have to see if she behaves herself in the morning now...
Thanks for all the suggestions guys.
