New some more bolts! Where?
24 Jan 2007
Guildford
I'm installing a XSPC RX360 into my system on the Corsair 800D, however neither Corsair or XSPC supply enough bolts for the amount of fans I have. I am putting a dual lay of fans on my rad - top & bottom.
Where can I get some more 'long' fan bolts - M4 30mm | Flat | Phillips Head. - in black if possible.
Is it possible either Corsair or XSPC would supply me with some more or would I be waisting my time?
Is there anywhere that sells them that isn't possibly a competitor, I've already tried B&Q and Wickes.
Thanks.
There's an engineering/diy shop near me which stocks a large variety of screws, so I'd look for something similar to that. Otherwise you're buying them online. Should be about 3p per screw.
M4 30mm is the only important bit btw, doesn't matter much what the head is on them.
Why didn't I think of Screwfix! Duh! lol found a pack of 25 for 1.21, not bad at all :) http://www.screwfix.com/prods/50074...n-Head-Machine-Screw-BZP-M4-x-30mm-Pack-of-25
And I wanted a flat head just because it looks a bit more flush, rather than having loads of screws poking out ;). I just didn't want countersunk ones really. The ones above will do find though.
