Hi,
I have a MK4 Golf GT TDi (Y Reg) which has developed a slight coolant leak, its mainly leaks when under pressure, I have checked the seals which look OK.
I have read about using products which you put in to the system to block the leaking area. One I ran into was radweld.
Does anyone know if there is any risk of blocking the coolant system with this or causing more damage? Also, are there other brands out there which do the job a lot better?
I am selling the car in about 6-7 months and alread have to spend money on the car getting it sorted, I really dont want to spend more having the coolant system ripped out to be fixed.
If you could let me know.
Thanks
DJMK4
Thanks
DJMK4
