Want 2 seperate Firefox browsers in 2 monitors, how?
5 Mar 2003
Swadlincote
ok im trying a move to the mac again for about 3rd time. Ive got an old (but perfectly good!) Powerbook G4 with Tiger 10.4.11 installed.
I like firefox for different reasons but am struggling to open 2 instances of this at once where as it was simple with windows. How can i get firefox on both monitors running independent of each other please?
TIA
TIA
Do you need two instances running or do you mean you want two separate windows? If you just need two windows press Command+N or go to File>New Window
Or if you want to put an existing tab into a new window, click and drag the tab off the tab bar and it will create a new window
of course....file > new window. What a numpty i am
Will check out that "click to flash" right now!
