Iiyama 27" B2712HDS
If you can afford the extra £50. I think the B2712HDS looks a much better monitor, and has the added HDMi connection, which sounds more future proofing than the E2607WS-1 :)
yeah the extra £50 is fine, the max ill go to is £300.
do u think i should get another 28" monitor, i know the backlight bleeding is poor but for gaming it'll be better?
I was asking you if the 1" is such a big difference for you ;)
It does sound like your leaning to the Iiyama, which is the one I would go for as well.
the 1" doesn't matter to me but the Iiyama 27" is 16:9 at 1920x1080 and my Hannspree 28" is 16:10 at 1920x1200, some people as told me both monitors needs to be the same res to do a one big screen for gaming. true??
i know i could drop the res down to 1080 on my Hannspree 28" but it'll look alittle weird.
Are there any technical differences between the B2712HDS and the E2710HDSD?
Reason: was reading a review and it was about to buy the B2712HDS but did not want to pay an extra ~£50 for the swivels stand and HDMI port which is the only difference that I have found between the two said monitors.
if you are decided on a 27 monitor.. check the samsung 2770HD which also works as a TV
and the 2709m from hp.
Me personally I am still not decided whether the 26" with 1920x1200 or the 27" with 1920x1080 is the way to go.
the 26 has a pixel size of 0.27~0.28 where the 27 goes up to 0.31
this is something that will make a difference on text reading..
unfortunately I have not seen a 27 from close.
I find it really hard to decide where to go.
From one point I am thinking that paying 300 for a technology which is 2-3 years old already is not worth it.
and again.. LG just announced OLED monitors
really confused on which road to go down
Well I decided to just branch out and order it, I guess I can return it if I don't like it afterall, pics and such given tomorrow :D
