I dont mind OCing it it it will help out, its under water anyway. Few things i'm going to try though is.
A. 9.12 Hotfix drivers
B. adding a +fullproc startup switch on the shortcut to force use of 4 cores.
C.
This insane suggestion
Amazingly this C. suggestion seemed to give me around a 10 FPS boost. I am pretty sure I was getting an average FPS in the 40's before, changing to X8 AA and I am in the 50's. Also max FPS in the low 70's now, which again I am pretty sure it never was before.
Cheers for this, oh go on I'll say it, heads up LOAM.
*Edit. I tried this last night and thought to thank you for it first thing this morning; I hadn't even read the post's since, to notice you had suggested it again a few post's above. Bloomin' went searching throught this thread to find where you said it aswell.
I haven't tested it extensively, and I find it hard to notice AA a great deal at my 1280x1024, though it does seem to look better too. Just seems so hard to believe. Cheers buddy.
As I said needs testing more though, because when I first came into game my FPS were lower than usual, in the 30's, and it felt clunky, like my settings do on high. Then after a minute or two, it settled at the higher than I was used to 50's and felt smooth again. As I said needs testing more.
*Re-edit Oh I am confused now, just went ingame to test. With AAx8 I was getting steady 60-70 going as high as 108 looking at the floor. Thing to note is there was only one other person ingame. I then re-verted to x2 AA and was getting maybe slightly better FPS and 120 looking at the floor. So......... Iam going to shut up and just play for now.
