Caporegime
- 9 Nov 2009
- Planet Earth
The HD4770 is a faster graphics card than a 9800GT!! It is between a 9800GT and GTS250 in performance!!
the £50 ones often lack useful things like core unlocking, and use lower quality components. the gigabyte ud2h boards are awesome for £70.
Actually they do!!
Almost all of the AMD motherboards which have the SB710 support core unlocking and so do many of the Nvidia 8200 and 8300 motherboards which have NCC. I have known quite a few people who have unlocked Sempron 140 and X2 550BE processors on cheaper motherboards. The advantage of the more expensive AMD motherboards starting at around £60 to £70 is the fact they have 8+2 phase VRMs and better cooling for the VRMs which is better if you intend to overclock a quad core on it.
The MSI 770-C45 is under £50 at many retailers in both DDR2 and DDR3 versions and can unlock a dual core or triple core CPU:
http://www.mitramsi.com/80-msi-770-c45-am3-amd-phenom-ii-x2-720-be-x4-unlock.html
http://edgemeal.110mb.com/AMD_Unlock/index.htm
The motherboard also has all solid capacitors which is usually seen in more expensive motherboards.
Both versions have the SB710 southbridge:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&cat2_no=171&cat3_no=&prod_no=1828
http://www.msi.com/index.php?func=proddesc&maincat_no=1&cat2_no=171&cat3_no=&prod_no=1812
Well then I just wasted £20 of my own money un-necessarily!
I spent a while agonising over which mobo to buy for my x3 435, and ruled out the MSI boards after reading they didn't support core unlocking. In fact I read it at bit-tech.net... (and a couple other places) *sigh*
"The MSI has the advantage over 785G boards in these areas but still lacks a very crucial feature: core unlocking. The board features ACC support and the SB710 southbridge so the facility is there to be taken advantage of. Hopefully a future BIOS update will enable it but don't hold your breath because no MSI board to date currently supports this."
I guess I paid more than I need to in buying a gigabyte GA-MA785GMT-UD2H. Now I need a hug :/ I hate wasting money... and I can't see anything that the gigabyte board has over the MSI now :/
AMD Phenom II X2 Dual Core 550 3.10GHz Black Edition £72Hi guys,
Wondering if you can help. My PC is OLD, currently has an Athlon Mobile 2500+ and an Nvidia 6800GT so I really can't play much, problem is I need to save for my wedding
I've managed to get £300 together to get this thing going again but it's been so long since I've built a PC, I've no idea where to start.
What would you recommend for CPU, Mobo, RAM & GPU? Will I need a new PSU?
Will DDR2 work in a DDR3 motherboard? I could buy the cpu & motherboard and add better ram at a later date if so.
No it won't but if you want to reduce the price of my suggested build and keep the DDR3 ram then just get rid of the graphics card like eddyc suggested since the mother board I recommended has an integrated ATI 4200. It won't be a graphics card that will be running everything on max but it should be able to handle stuff pretty well I think. Depends on if you'd rather sacrifice graphics or ram but from what I hear you won't notice too much of a difference between DDR2 and DDR3 ram anyway but that might depend on if you use it for more than gaming.Will DDR2 work in a DDR3 motherboard? I could buy the cpu & motherboard and add better ram at a later date if so.
