Funnily enough, I've just seen this:
http://forums.overclockers.co.uk/showpost.php?p=15788822&postcount=641
Which is the same board, with the H50 mounted, you can see the pump connector going to top right of the board, which is the pwr_fan(98% on name) header, so I'm assuming I got it right in the first place..
I can only assume it's seated it's self incorrectly, although the little teeth on the bracket are in place correctly, and it's screwed down as much as you would, so effectivly the threads have bitten together tight together, and then a notch more.
idled 26c in windows for about 4 hours whilst doing updates and what not..
