E5200 3.6 OC using stock cooler/4.0 using Corsair H50-1
Finally finished my Intel Dual Core E5200 budget rig using the following components,
Gigabyte P35-DS3R Mobo (Just updated to F13 bios)
Corsair Dominator 4GB (2x2GB) DDR2 XMS2 PC2-8500C5
NVidia 8800 GTX
Antec P183 -
Antec CP 850W Modular Power Supply
Western Digital Caviar Blue 160GB ATA-100 8MB Cache -
LG GH22NS50 22x DVD±RW SATA ReWriter (Black) - OEM
Akasa AK-CB002 PWM Fan Splitter Cable
4 x Akasa AK-FN058 Apache Black Super Silent 120mm Fan (Replaced all the case fans)
Running on stock cooler and 1.3250v VCore, I did some quick test and here's the somewhat amazing results.
IBT 5 runs on max mem
WEI
It seems too good for a stock cooler, don't you think? I've also noticed the following;
1. Max CPU temp 58c according to CPUID HW Monitor but Cores 0 & 1 has never gone up beyond 57c on both Core Temp and Real Temp. Is it possible that the CPU gets more hotter than the cores?
2. CPU fan has gone up to 1704 rpm max. Sometimes, figures goes down to 0.
3. Memory speed seems too slow as reflected on the GFlops.
4. GPU temps seems too hot and idling at 50 - 54c
Any recommendations from the Guru's here on how to improve the above set-up? Of course heatsink will be replaced once I get my hands on any spare at the MM.
This is my third build but my first on Gigabyte boards so it's kind of "Walking blindly in the alley".
Comments, Critics and Advises are very much welcome.
NVidia 8800 GTX
Antec P183 -
WEI
