I have been developing this tool on/off for some time now. its basically a code organizer, i wrote it for myself originally a few months ago just store delphi code and things, until recently ive started adding other programming languages that might benefit some people here.
It now supports c++, delphi, javascript, perl, php and visual basic, other languages are also planned.
Ive looked in the past for freeware code organizers and cannot find a decent one, so here is my alternative, free to all
Key Features:
Latest Screens (v1.44):
Now comes with installer to associate languages with the program as you can see below
Program is in much of need of testing so do step up and report!
Older Screens:
http://i49.tinypic.com/2hfmag5.jpg
v1.44 Beta DOWNLOAD HERE: (2.09MB Zip)
see Read Me.txt file in zip first, program is in testing stages and is reccomended to not use it fully yet until tested thoroughly! once im 100% sure everything is ok i will give the go ahead so you can start adding your items in. you wont have to copy and paste them all, you will be able to import them (one at a time at the moment) or drop them in the editors.
will keep you updated.
version 1.3c and before are now obsolete, dont use those versions for saving/loading - they wont be compatible with v1.4!
Key Features:
- Simple and easy to use WYSIWYG interface
- Multi programming languages support
- Add groups to the database allowing structured layout
- Ability to drag and drop groups, documents and snippets for flexible arranging
- Fast database saving and loading
- Full rich-text Document editor
- Syntax highlighting capabilities thanks to SynEdit classes
Older Screens:
