Car Juddering Under Acceleration
18 Oct 2002
Chesterfield
I hope you mean 1.5 to 2k. Even then you shouldn't be fully loading the engine below that rev range.
Check the air filter first, does it idle okay, and fault lights?
Could well be bad fuel. I think I trip to Shell and a full tank might be in order.
26 Nov 2007
Coil pack?
Doubt its a coil pack as its an older model-
Could be dirty fuel, plugs or leads. Might also be worth removing the distributor cap and cleaning the contacts. Number 2/4 here
17 Feb 2007
Walsall
Apply hand brake, first gear, start to lift clutch. If it judders as the clutch starts to bite, start crying and go suffer a £1000 bill for a new DMF and Clutch.
LOL in a 1.4 petrol - No DMF and new clutch is about £250 - £300
Coil pack, Distributor cap, HT Leads, could be damp due to the recent weather - get a can of WD40 and spay these
8 Mar 2006
Near Winchester
Sounds like an ignition related issue to me. Does it go away when the car warms up? A change of plugs and/or leads might be in order
I'm going with this for now, the fuel is probably not coincidence, it's harder to ignite (higher octane maybe), and so has highlighted an existing ignition system issue.
