- 12 Aug 2005
- Orpington.
I have an offer of a cheap 5870 from a friend so I was thinking of pairing it up with my 5970, is this possible and what are the performance benefits? (if any).
ive been told its not possable to CF a 5850 with a 5870, so i dont think youl CF a 59 and a 58??
What happens if I don't clock my 5970 to 5870 speeds will the 5870 downclock?
Wish I had a friend like that, in fact, I wish I had friends!!
My 5970+5870 @ 900/1300 rig pulls up to 850 watts at the wall (approx 710w load on psu worst case scenario for me assuming 80% efficiency) with an i7 @ 4.0GHz + a load of other stuff in there ....
That is with Prime 95 AND Furmark on the go at the same time .... normal gaming sees approx 200w less that that at the wall ...
Oh, the clocks are not set to match each other by the drivers if they start out different so no downclocking .. another myth busted![]()
Have you got this set up ninja?
Shall I go for it or not?
Vsync it for 60fps ... nice.
Nice!
I think I will get it then, thanks mate![]()
It's thought of as overkill until you play Crysis, so just to give you an idea check out the AA settings on thisVsync it for 60fps ... nice.
Stalker Clearsky with literally everything maxed out including sunshafts is smooth and cool at times ... it was not quite there with the 5970 on its own.
Apart from those 2 and maybe 140fps in Dirt 2 DX11 maxxed out I can see no benefit whatsoever but yeah, if you fancy it then go for it!
