Hey all,
I have that annoying itch again... the itch to upgrade, however I am not doing bad as my current PC is almost 4 years old, and I have not actually upgraded it once:
AMD X2 4800+ 2.4Ghz S939
Asus A8r32-MVP Delux Mobo
2x 1GB PC3200 OCZ DDR1
2x 300GB Maxtor 7,200RPM SATA HDD
ATI X1950XTX 512MB PCI-E
Cooler Master Praetorian 730
Enermax eg701ax-ve 600W PSU
I generally use it for browsing the net, a little 3D work (Practice in 3Ds Max) and some gaming. L4D2, and Dawn of War 2 currently being the most demanding games I play. The system does allow me to do what I want still, however it is starting to struggle as it gets older (No Surprise)
Now there are a few games coming out this year that I like the look of Supreme Commander 2, Command and Conquer 4, Stalker 3, RUSE, SW:TOR, Etc.
I know I will most likely be able to run all of these however not to a very high standard, probably low – med settings (Which saddens me, just a little). However having said this most of my gaming time is now spent on consoles, having decided to invest in a 360 about a year ago.
I understand that an "upgrade" is somewhat out of the question, as whatever I throw at my system it will be bottlenecked by something else, thus I will need to replace most of the components. Any who here come the questions:
1) Considering my use of the PC do you think its worth indulging my itch and investing in new hardware, or should I ignore it until I really get back into PC gaming?
2) Would I be better off overclocking my current system, instead of upgrading?
3) If I were to upgrade would my PSU and case still be sufficient both power and space wise for todays hardware?
4) Would it be worth upgrading my hard drives, or just leaving them, taking into account their age?
5) Most importantly if I were to upgrade what hardware would you guys suggest, based on my use of my PC etc?
P.S I am currently running Windows XP MCE, however have invested in Windows 7 Home 64Bit, but have not yet upgraded to it as I am unsure if my current hardware will agree with it.
Thanks for any help and advice!
Jcb33.
Jcb33.
Can you do the same please??
