- 7 Feb 2010
I need to capture in HD and render HD and I am told the i5 750 over clocked will be more than enough so not to bother with i7.
Right or wrong?
Right or wrong?
For rendering purposes the i7 comes into its own league, it is simply amazing at rendering and encoding processes and the like.
However don't get me wrong the i5 is still a brilliant CPU but if the main use is for encoding etc then the i7 would be the best choice.
not much of a difference between the two http://www.anandtech.com/bench/default.aspx?p=47&p2=109
Thanks for that, after comparing your right, there is not a great deal of difference so why is the i7 920 £50 more than the i5 750?
The Core i7 860 has HT too and is a socket 1156 processor.
I assume the OP is also going to invest in a fast hard disk or an SSD as this could be a bottleneck in the system too.
OP = PC user right?
Yes I will set-up Raid 0 but I won't need that until I need to record uncompressed. I already have a Seagate Barracuda 7200.12 - 500GB but it is 16MB cache so I will get another 2 at 32MB cache as I read more cache is better for writing and that is why I am building this system.
When it came to encoding I think the i5 was around 70% slower in some cases... Of course this doesn't mean that it is slow in any sense of the word, merely when comparing to the i7 in that scenario it was deemed "slow".
dont be daft in extreme cases hyperthreading offers upto 20% more performance compared to no hyperthreading.
i7 920 is not 70% faster at anything compared to an i5 750 its not even possible when the chips are so similar
As much as i7 920 will certainly help in that, the main question is:
"Do I really need to do it so fast? "
Whats your current setup, how fast does it deal with task and how much faster you'd like it to do it?
How often do you do that as well?
I mean, you don't really need i7 or even i5 if it's once a week odd render or something ...
