The 1200 is huge!
Still going with my opinion that that case is too big
You've done a good job though, Just a bit of constructive criticism though. The DVD drive (Im assuming thats what it is at the top) wires should be able to go up the top and theres a small gap to fit the wires down and behind the mobo tray, Makes it look a lot tidier. Alont with tucking those Sata cables in a bit more so theres not loads of slack showing.
Also, Whats that running down the left hand side of your mobo?
i dont think the antec 1200 is that big,if i could by another tower a lot bigger with the same great things as the antec 1200 i would...have fun with you new tower![]()
Loving the space in this case
Hoping to get some watercooling in it before the end of the year so it'll look quite small then
Yeah, I have the 902 and I thought that the 1200 was literally just a bit bigger. Shame that it doesnt have the gap, I found that very handy to hide odd wires. All the front panel connectors went down there and are now completely out of sight.The DVD drives cables are in the highest opening available (are you thinking of the 902, it does have a gap at the top for cables)
