Yeah, use MSI Afterburner instead.
you can get riva to work, you need to take the vendor id from gpu-z and stick it in the rivatuner.cfg file. it won't read the core speed properly (says my 5870 is at 32xxxMHz), but it will clock it up and down
EDIT: it'll also show your memory clock as 2x (or 1/2 depending which way you look at it)
ok nice ty
i have a device ID and a subvendor which one?
sorry, yes it's the device ID; put that number in the .cfg file for riva, under the heading of [GPU_1002]; scroll to the bottom of that section and add it to RV770 and it should work (that's all i did for mine)
