Probably, or you could just do a clean install using a disk from the upgrade pack.ok thats fine, but i can use the full version discs with a upgrade code from the 3 pack of upgrades to put 64bit windows 7 on?
Ok il use the upgrade disc to to install it.
Are people diffently sure you can go from 32bit xp to 64bit windows7?
