This is the guide I am following: http://www.sevenforums.com/tutorials/5166-dual-boot-installation-windows-7-vista.html
So I have read lots of pros and cons of duel booting, but what do you think? The reason I want to do a duel boot is that I cannot afford to do a clean install with all my programs etc. I will do this over two hard drives because I have heard lots of horror stories with Vista + Win7 on the same HDD. This will be my config:
Disk 1:
Vista HP 32bit+ Programs programs and files
Disk 2:
Win7 64-bit
My questions about this are:
1) Can I risk damaging my files on disk 1?
2) My aim is to use Win7 after upgrade as if nothing has changed, will this work?
3) Will I get the Windows Boot Selector at startup, because I dont want to edit my boot preferences in the BIOS every time!
4) Will I be able to access all my programs OK from Win7?
5) Should I backup drive 1 first?
6) Is it a good idea?
7) Will I have any hardware driver issues or problems with the 64/32-bit barrier?
8) Anything you would like to add to the guide
That should be everything I need to get going!
Disk 1:
Disk 2:
Win7 64-bit
best done on a spare PC.
