- 4 Feb 2010
Hello there!
I have an old graphic card I want to upgrade:
nvidia Geforce 8800 GTX
Ideally I would like to buy:
EVGA GeForce GTX 295 Co-Op Superclocked 1792MB GDDR3 PCI-Express Graphics Card (Single PCB)
or a
XFX ATI Radeon HD 5870 XXX 1024MB GDDR5 PCI-Express Graphics Card
However, when I contacted the sales support of overclockers u.k. they warned me saying that the new graphic card would be 2 inches longer. D'oh!!! My question is:
How do I get the dimensions of the new grapic cards ?? I tried to look around but I did not find anything.
Also, what if it is really longer than my previous graphic card? Should I give up upgrading my pc just because of the dimensions of the new GPU?? I am not really expert and I do not know if I can slide my motherboard or drill a hole in my case!!! Sadness!!!
Is there any graphic card which I can fit and would give a good improvement in performances?
I'll paste my pc description in case it is useful:
1] Aurora™ 7500
Chassis: Alienware® P2 Chassis - Space Black
Chassis Upgrades: Alienware® AlienIce™ 3.0 Video Cooling - Lunar White
Power Supply: 700 Watt Alienware® Approved Multi-GPU Power Supply
Motherboard: Alienware® Approved NVIDIA nForce 590 SLI Motherboard
Processor: AMD Athlon™ 64 X2 4600+ Processor with HyperTransport and Dual Core Technology
Memory: 4GB Low Latency DDR2 Performance SDRAM at 800MHz
Video Card: 768MB NVIDIA® GeForce® 8800 GTX
System Drive: Single Drive Configuration - 250 GB Serial ATA 3 Gbit/s, 7,200 RPM with 8MB Cache
Optical Drive One: 18x Dual Layer DVD±R/W Drive
Sound Card: High-Definition 7.1 Performance Audio - Standard
Network Card: Integrated High Performance Gigabit Ethernet Adapter (DSL-ready)
Removable Storage: Alienware® 28-in-1 Digital Media Reader / Writer
The Motherboard is a Foxconn and I think that the number is foxconn n15235 and I can give you more info about it, just pasting the Everest report:
[ PCI Express 1.0 x16: EVGA e-GeForce 8800 GTX ]
Graphics Processor Properties:
Video Adapter EVGA e-GeForce 8800 GTX
BIOS Version 60.80.0A.00.01
GPU Code Name G80GTX
PCI Device 10DE-0191 / 3842-C831 (Rev A2)
Transistors 681 million
Process Technology 90 nm
Die Size 484 mm2
Bus Type PCI Express 1.0 x16 @ x16
Memory Size 768 MB
GPU Clock (Geometric Domain) 576 MHz (original: 576 MHz)
GPU Clock (Shader Domain) 1350 MHz (original: 1350 MHz)
RAMDAC Clock 400 MHz
Pixel Pipelines 24
TMU Per Pipeline 1
Unified Shaders 128 (v4.0)
DirectX Hardware Support DirectX v10
Pixel Fillrate 13824 MPixel/s
Texel Fillrate [ TRIAL VERSION ]
Motherboard:
CPU Type DualCore AMD Athlon 64 X2, 2400 MHz (12 x 200) 4600+
Motherboard Name Alienware nForce 590 SLI Motherboard
Motherboard Chipset nVIDIA nForce 590 SLI, AMD Hammer
System Memory [ TRIAL VERSION ]
BIOS Type Award (02/08/07)
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID 02/08/2007-alienware-6A61HP22C-00
Front Side Bus Properties:
Bus Type AMD Hammer
Real Clock 200 MHz
Effective Clock 200 MHz
HyperTransport Clock [ TRIAL VERSION ]
Memory Bus Properties:
Bus Type Dual DDR2 SDRAM
Bus Width 128-bit
DRAM:FSB Ratio CPU/5
Real Clock 362 MHz (DDR)
Effective Clock 723 MHz
Bandwidth [ TRIAL VERSION ] MB/s
Any suggestion will be welcome.
the sales support of overclockers was fast in replying, but really really really short on suggestions. Bare in mind that this is the 3rd time I contact them and the best I got was the statement " Ur old graphic card would be 2 inches shorter".
Cheers guys!!!
or a
1] Aurora™ 7500
Die Size 484 mm2
Memory Size 768 MB
Pixel Pipelines 24
TMU Per Pipeline 1
Motherboard:
Bus Type AMD Hammer
Real Clock 200 MHz
Bus Width 128-bit
Cheers guys!!!
