The story starts in the bad old days. I was bumping my FSB up one at a time, aiming for 3.7/3.75. (On a Q6600 which was Prime95-ing for 8 hours at a time at 3.4ish without missing a beat btw, on a GA-965P-DS3)
Posted fine at 3.68, into Windows, all lovely. Decent temps even at load, etc. Thinking 3.7 should be within my grasp, I rebooted and set to 3.69. POSTed fine, but Windows froze on the startup screen. So I turned off, and back on again. It gave a nice long beep, probably 2 or 3 seconds and rebooted itself.
Upon subsequent POST, it was back at stock speeds. Works absolutely fine, as you could tell if you were here - I'm using it. (phew, might I add.)
So I go to try an overclock again. Whatever settings I enter are over-ridden every time and it POSTs at stock 2.4. Yet when I got back in to the BIOS, all the overclocked settings are still there.
What terrible mistake have I made, how badly will I be mocked, and is there anything I can do about it? Tried re-flashing the BIOS to no avail.
If I can stop banging my head off the wall soon I might sustain consciousness.
