- 4 Jan 2004
- ¯\_(ツ)_/¯
Well I guess it's better to prepare for worst case scenario really when doing things like this... 200W is a nice figure to shoot for. A 100W lightbulb gives off a ton of heat, so 200W isn't going to be easy...Think this looks like his PSU: http://www.80plus.org/manu/psu/psu_...ower_and_Cooling_Turb_Cool860-860W-Report.pdf
200W looks correct if the PSU is at full load, but agreed it would be a lot less with a typical load though. Still, whether it's 30W or 50W or 70W it's still a fair amount of power to remove.
I guess the best thing to do would be measure the load from the mains when the computer is flat out (benching), this way you can work out with a little maths how much heat you're going to be dumping into your watercooling system. I'm not really familiar with heatsink calculations however, so I normally go for the biggest heatsink I can get, and then feel to see how hot it gets under normal use.
I've made a fanned PSU into a fanless PSU before now, it involved removing all the IC's from the PSU, and simply bolting them to a huge 2kg Alu heatsink, and having leads from the PSU to the IC's. It worked, however this was for a low power Epia rig, something like a Pico-psu would have been much better had it been available back then.
		 Has been an interesting read though
