Turbo gone?
B&W
B&W
3 Oct 2003
Birmingham
Was driving a octavia vrs today, in third on the duals was at around 80mph I shifted to fourth and put the foot down it wouldnt move instead loads of white smoke started bellowing out the exhaust.
The power was gone also and the engine management light came on, just about managed to get it home. There was so much smoke, need to gets put on a recovery truck now.
Everyones saying the turbo's gone, im pretty sure it is but could it be something else?
Well, it sure sounds like its burning oil..!
It could be something other than the turbo though I'd imagine.
Did the seller assure you that it used no oil and that this was a sign that the turbo was in good condition?
Turbo's definitely gone. Classic symptoms.
Here's an E46 with a blown turbo. Look similar?
Why this idiot decided to drive backwards and fowards and gun the throttle I shall never know....
To be honest, it could just be a split intercooler pipe?
That wouldn't explain the white smoke billowing out of the exhaust though.
It could be a head gasket, coolant getting into the cylinders makes a lot of white smoke. Turbo seals blown tends to give a blue tint to the smoke, and it stinks. Or the real nasty would be a melted/holed piston. Is it standard or has the engine had a boost increase?
This produced so much smoke from my car it obliterated the road:
Yep, the bearings in the turbo have gone, mine did exactly the same.
Around £500 - £600 for a new unit then £92 for the gaskets, then a normal oil and coolant change price, if you take it to a backstreet independent its around 1.2k's worth of work.
Ouch. - I think I better start preying now for my turbo to hold out... Although it's obviously the point to upgrade to a ko4 or if not perhaps the jbs hybrid.
I took the blowing up of my KO3 as a chance to change to a Ko3's, then Ko4 :p
Turbo prices are reasonably similar for the Ko3's and Ko4, about £100 in it iirc, turbo fitting parts are;
1x Cat Gasket
1x Manifold Gasket
3x Manifold to Turbo Bolts
3x Exhaust Nuts
8x (iirc) special silver crush washers (for the water lines
1x Oil return line gasket
Around £92 irrc.
£45 for 5w30 oil
£6 for an OEM filter
£30 for some good quality coolant
Much like my other car work i changed the turbos myself, first time it took about 8 hours, 2nd and 3rd about 4 - 5 hours, however with my engine layout i have better access, the VRS is Transverse iirc?
I'd hate to think how much labour adds to the bill, around 5 hours at £70 an hour, not nice!
Mine is a Seat Leon so transverse yes, unfortunately I know I'm not up to the job of a turbo change myself.
Regarding the turbos, are you running a k04 now? I was under this impression this required a different down pipe, have you used a different intercooler?
The Cat / Manifold and turbo shape is different for the longitudinally mounted 1.8T, the upgraded ko4 is of exactly the same shape and inlet / outlet design so its a bolt on upgrade, which is nice.
Intercooler wise, i've gone custom front mount, forge wanted something stupid for similar sized core and pipework.
[TW]Fox;15937682 said:
Did you buy it from DannyW? At gunpoint?
your a lowlife i dont wish bad luck on no1 but in your case you deserve it and when everyone laughs at you then youll know how it feels like.
/awaits karma
After picking my way though the dire spelling, grammar and complete lack of punctuation, I want to know who this number 1 is?
Also why are you defending someone who blatantly lies to sell ropey old cars?
