No. You can't upgrade but you don't have to install on a new partition either. Starting the install from within XP and doing a "custom install" it will move the older version to the "windows.old" folder along with the associated "windows" "program files" and "documents and settings" subfolders.
When upgrading from Windows XP to Windows 7 you must upgrade the version currently installed within Windows XP to the corresponding version in Windows 7. I.E. Windows XP Home to Windows 7 Home Premium; Windows XP Professional to Windows 7 Professional. Also, please note that when migrating from Windows XP to Windows 7 you will not have an "in place upgrade" option. You will however have the option to select "custom" install when prompted. The Windows 7 install process will then copy all of your data in "My Documents" over to a Windows.old folder within Windows 7 itself. All applications and documents stored in other locations will have to be reinstalled / transferred manually.
For more information on the Windows 7 Upgrade, please go here: http://bit.ly/3DvynK
