Fractal Design R2 cooling advice!
5 Dec 2008
Buckinghamshire, Marlow
Hey hey,
I just got the Fractal Design R2 case and was thinking of adding 2 more fans..
Im really not sure which would be the best place for them... maybe the top?
It currently has 2 fans: 1 x 120mm front intake and 1 x 120mm back exhaust..
Also which fans do you recommend?:)
Thank you!
Im planning the following. Im using the same case and will have 5870 too.
2x 120mm Fractal fans front sucking IN
2x 120mm Enermax fans rear (H50 push/pull) IN
1x 140mm Fractal fan bottom sucking IN
2x 120mm Fractal fans top exhausting OUT.
