Left the tap on again!
Here is my effort, quite happy with the result, but still could be improved.
Good effort, non macro lens though im assuming?
Nice, would a Macro lens make a big difference to taking these sort of pictures?
Yes ;) both mine and famas pictures are taken with macro lens, mine with a Tamron 90mm F/2.8, famas with a Tokina 100mm F/2.8.
Have been trying this one out myself today (thanks Famas!), the Sigma 70-300 macro really isn't macro (I had to add on a 31mm Kenko tube to get as close as possible) but it served its purpose.
1.
2.
I'm going to have to investigate a cheap and cheerful macro lens for a Canon, does anyone have any suggestions?
Cheers
Great captures, well done.
The Tamron 90mm is just over £250 at onestopdigital. It gets very good reviews.
You could probably get the Sigma 105mm and Tokina 100mm for a similar price second hand, they all perfor very well.
Canon do two types of 100mm as well.
Hehe, thanks! :)
Will check out those lenses now, £250 sounds a lot better than the £400 plus I've been seeing for the Canon models.
The trickiest part of the process is pressing the shutter at the right time, With a bit of patience you soon start to get the hang of it.
I notice your using a Nikon, therefore cant you use continuous shooting ?
I just tried it in the bathroom sink and completely failed, couldnt get the dripper to drip whilst taking the shot at the same time :lol:
My camera doesnt support remote trigger nor do I have a tripod atm :(
