- 10 Feb 2010
- Oxfordshire
As above really, i am stuck between a spec with an AMD or the I5 processor?
Cheers Chris
Cheers Chris
I'd pick the i5 750 out of those 3.
Might be worth considering a full system build though. You might find other platform features swing it once you've budgeted for everything.
Budget is £600 but I need to include an operating system in that!
Seems the consensus is the I5 on the overclocking basis. I am a complete newb at computer builds and wouldnt know how to overclock!
you press del after you press the on button then hit page up 20 times, save, and restart. done
before you start trying to overclock its best read this thread.
Get the i5 750 it's easily the best i5 cpu. Anandbench to the rescue for some numbers
http://anandtech.com/bench/default.aspx?p=102&p2=109&c=1
An overclocked i5 750 will destroy the Phenom especially for CAD rendering, but if you run to plan to stay at stock there's probably not much between them.
