While I had some problems getting the actual website to load (Getting hammered I'd assume), the game downloaded perfectly fine, and it works great under win7 64-bit, though I do have UAC disabled. Windowed mode is pretty much useless though unless you set your desktop to 16-bit, so you have to play fullscreen. Editing the sun.ini gets you any resolution you like. And naturally, it doesn't need a CD to be in the drive, the .rar you download is the entire game. Just extract it to wherever you want it and run game.exe, it loads and asks if you want Vanilla or Firestorm.
As for playing online, see this: http://na.llnet.cnc3tv.ea.com/u/f/eagames/cnc3/cnc3tv/TibSunFreeware_install.html
Small note, the .reg file assumes you install it to c:\program files\ea games\Command & Conquer The First Decade
If you install it anywhere else (Including progam files (x86)) you'll need to edit the reg file accordingly.
