How on earth did you get the MB for £40?
When you put it like that! Crikey. Can you list and link all your components matey? Looks like a cracking little rig for the money then I can recommend it as a build to all the people that I build machines for. Add in a £70 Gfx card and at £300 that's a cracker.
I just used that chess bench on my q6600 rig and it got 19.42 and 9323 @ 3.5ghz, so it's close. Super pi gets 6 and 14secs for same tests. I notice the vcore is quite high though? Or is that normal for the x4 cpus?
Is it Prime Blend stable at those settings?
I'm not liking the look of how long it's been running in the screenshot.
.Looking good so far mate good luck with it just out of interest what case did you go for? Just some cheap flimsy thing I assume![]()
16 minutes Prime Blend (or even 25...)? As a quick indicator that it's OK that's alright but you really need to let it run for a few hours. Many a time it's looked OK and then I've come a cropper at around 4 hours or 7 hours.
If you want a quicker test, how about Intelburn or S&M?
Ye well fritz and super pi aint AMDs best but the main point is that this thing will play games just as good as i7 and costs hardly more than just the CPU itself.
That's undeniable. Can't argue with you there. In fact I have read many a time on these here forums, that a fair few people prefer AMD rigs as they are perceived to be the "smoother" choice during gaming. Aka FPS is no different but it runs smoother. I'm not sure exactly if anyone has anything to back this up technically, but I would assume it would be to do with differences in the Architecture, namely, the on board memory controller for the AMD cpus? I could be way off here though so please correct me someone.
No - you've thrown in a quad core but the OP was proposing a dual and unlocking it to quad.
Edit: OCUK has in the 550 for about a tenner less. The 555 is widely available (just not here yet) but supposedly has a better unlock rate.
Hang on a sec, not sure about your prices there as some look like second hand ones?
I can't find that AMD CPU for sale anywhere? I'm only seeing THIS @ £121, and as for mobos, they start at about £70 for a decent one on AM3 socket. RAM I agree you can get 2 x 2gb of DDR3 for £80 ish. So that makes....
RAM = £80
Mobo = £70
CPU = £120
Lets keep the cpu cooler @ £17.99
Case = lets say £30.
That comes to £317.99
Now price check on the same stuff swapping the mobo to an I5 and the CPU to I5 750:
Ok ish Mobo = £100
I5 750 CPU = £138
Total = only £48 more for I5
Have I miscalculated here as it does not look so good to me now. Plus the i5 750 outperforms the 955 in tests.
