nVidia drivers crashing
4 Dec 2002
Bourne, Lincs
Have a 285GTX
Just recently when playing certain games, I will get the lovely error Kernel mode drive has stopped, recovering blah blah
Now I have tried the latest nvidia WQHL and beta drives but it makes no difference
PC Spec
E6400 @ stock
GTX 285OC2
4 Gb [4 x 1Gb]
2 raptor drives
1 1.5tb samsung drive
Corsair HX520
DVD burner
Running Windows 7 Pro x64
Anyone have any ideas on this?
Kimbie
I would under-clock the card to standard clock speeds using MSI Afterburner or Rivatuner just to rule out the OC, There seems to be a lot of OC'd cards running into trouble.
PC2 6400 Gigabyte DS3P
Well I have been running this card for months with no problem, this problem has only cropped up in the last week or so.
Its a BFG card
Kimbie
Try furmark should help to narrow down whats causing the problem.
I would start with Intel Burn Test - 20 passes - to make sure the rest of the system is stable
Then Memtest86+ to make sure the RAM is ok
If it passes those 2 ok then move onto testing with furmark.
