having it online would be a good thing, however having it offline is good if there is no internet access.
i started improving a few things, added c++ language aswell.
regarding the previous talk about such a program been useless, as you can see from the updated pic in first post, i started adding some things, notice the selected document i added isnt exactly code you would put in a dll for example.
this updated version will be up in a few days for those interested
i started adding some common groups and basic snippets to it, which could be used as a starter database.
I never said it was useless, I just said that snippets should be "snippets" not huge swathes of implementation and logic.
You could have created a program to help co-ordinate terrorist attacks. It might be well coded, it might be useful to terrorists, however I don't agree with terrorism.
Is that clearer?
Why do you set the languages that are allow - why not just let people add the libraries they want or am i missing somthing?
I think he means couldn't you have a way to add a language table to the database and have the user being able to create/add a new language category. But that all depends on your DB design really
Either way, I think you should build in a function that lets the program update itself when you release a new update, release the program on your own website
If you want to, but don't know how an update function could happen, or if it would slow down your system, I can probably help, although I don't know Delphi.
I want a copy...
yeah i should maybe make the c languages merged under one name.
as for the auto update i assume a website is needed and its a case of storing a ini file on the site, download it silently and read it from the program and compare the version number information. i dont have a website though and have never tried this.
will try and get a download link up some time tonight, im just trying to fix some minor problems first...
I can get you probably free hosting and web domain if wanted.
Just grabbed a copy and had a quick look - superb mate, suits my needs down to the ground.
I see a lot of copy and pasting from my random text files into this app!
Could I put in a request for Perl to be included in there some where please - yes, there are still a few of us die hard Perl'ers!!
That aside, thanks for sharing your app.
- im pretty sure you wont, but best to play it safe as always
