Presumably you won't be using it for recording since you are looking at a Revo. I use XBMC and it has a lovely interface - it runs great on a Revo.
However there are other options on the market now such as the cyclone mkv for cheaper than half the price of the options above. Doesn't look too bad, decent remote control and does the job just fine.
Like the look of that!Have a look at the Foxconn nT330i. Can be had for as little as £140 as a barebones, and is a very nice bit of kit (using mine right now).
Looks good, but is there an alternative with N wireless?
Hi,
I'm thinking of getting one of these next week
Any chance of some photos of it (external and internal)
Does S3 sleep mode work correctly on it?
Any chance of some pics of the internals of the unit?
Whats the build quality like?
I like the size of the unit, but reviews about the noisy fan are putting me off.
For the money you really can't complain, a few minor issues you should be aware of.
GFX memory allocation can not be changed in the BIOS, and is dependant on your system ram (1gig=128mb, 2gig=256mb, 4gig=512mb). As long as you have 2gig of ram 1080p will be fine.
It's a massive pain in the butt to get the lid off.
It can be very noisy if the CPU is being worked hard. Long term I think I'll either remove the lid or cut it and put a fan grill in.
No fan control available in the BIOS.
S3 works fine from both Windows 7 and XBMC live, USB wakeup works once enabled in the BIOS.
Depending on what you have lying around (laptop ram/hard disk) you might find it cheaper to go for the Revo 3610 linux edition which comes with 2gig ram and a 250gb hard disk for £200.
