GIGABYTE GA-X58A-UD7 F2
MB Intelligent Tweaker(M.I.T.)
Advanced CPU Features {Press Enter]
CPU Clock Ratio............................: 21
CPU Frequency .....(Ghz)...................: 4.01
Intel(R) Turbo Boost Tech..................: enabled
CPU Cores Enabled..........................: all
CPU Multi Threading........................: Enabled
CPU Enhanced Halt (C1E)....................: Enabled
C3/C6/C7 State Support.....................: Disabled
CPU Thermal Monitor........................: Disabled
CPU EIST Function..........................: Enabled
Bi-Directional PROCHOT.....................: Disabled
Virtualization Technology..................: Disabled
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*...........................: 6.87
QPI Link Speed* ......................(Ghz):x36
Uncore Clock Ratio.........................: 17x
Uncore Frequency......................(Mhz): Auto
Isochronous Support........................: Enabled
Advanced Clock Control [Press Enter]
>>>>>Standard Clock Control
Base Clock (BCLK) Control*.................: enabled
BCLK Frequency (Mhz)*......................: 191
PCI Exxpress Frequency (Mhz)...............: 100
CPU Clock Drive (mV).......................: 800
PCI Express Clock Drive (mV)..............: 900
CPU Clock Skew (ps)........................: 0
IOH Clock Skew (ps)........................: 0
Advanced Dram Features [Press Enter}
Performance Enhance........................: turbo
Extreme Memory Profile (X.M.P.)............: disabled
System Memory Multiplier (SPD).............: x8
Memory Frequency (Mhz).....................: 1528
DRAM Timing Selectable (sPD) ..............: Quick
7-7-7-20-1
Advanced Voltage Control [Press Enter]
>>>>CPU Voltages
LoadLine Calibration.........................: level 1
CPU Vcore....................................: 1.27500
QPI/VTT Voltage..............................: 1.275V
CPU PLL......................................: normal
>>>>>MCH/ICH Voltrage
PCIE.........................................: auto
QPI PLL......................................: 1.14
IOH Core.....................................:1.14
ICH I/O......................................: auto
ICH Core.....................................: auto
>>>>>Dram
DRAM Voltage.................................: 1.640V
DRAM Termination.............................: auto
Ch-A Data Vref...............................: auto
Ch-B Data Vref...............................: auto
Ch-C Data VRef...............................: auto
Ch-A Address Vref............................:auto
Ch-B Address Vref............................:auto
Ch-C Address VRef............................: auto
much appreciated
i don't suppose you know what your cpu pll is ending up at? i've got mine on 1.3, seems fine.
also, do you notice a difference between performance enhance 'turbo' and 'standard'? i've left it on standard (due to it claiming to be more stable).
cheers![]()
It is recommended to leave CPU PLL at default 1.800
It could be your low CPU PLL which is causing your problems.
Bios F4 enhance memory compatibility so maybe it will be good for you.
I didn't try before to use standard and I think difference will be minimal.
cheers![]()
@twisted are you using load line calibration? I had issues with a P45 board where llc enabled caused the voltage to drop slightly too far after an idle period, but with llc off (and a slightly higher vcore set to compensate for this) all was well.
