Hey how old is the 555 chip? I'm looking for an upgrade for my old Core 2 Duo system and seriously considering this chip. Are you still running the stock cooler on it with the X4 unlock?
How old as in?
If you mean the release date, they came out just around 2-3 weeks ago.
It's the upgrade version of the old 550 with 100mhz clock bump and on the new c3 silicon that's been used for 965BE so it's bit better for OC.
I'm not using stock cooler, I run it on the Zalman 9700 that I picked up off ocUK from the deal for 17.99 last week.
http://overclockers.co.uk/showproduct.php?prodid=HS-026-ZA
Grab one fast if you still can, those were going for 40quid not long ago.
Not as good as the newest stuff out there but it's not far behind.
And it also looks from my little research that all the first batches unlock successfuly as I haven't found a single person or review yet in which they didn't unlock so probably AMD just rushed for release due to i3 coming out so they just took a bunch of 965BE's and disabled 2 cores and lowered multi.
Even when not unlocked, this chip is still amazing as they seem to do ¬4ghz mark quite easily as a dual.
I'm sure I could get 3.9-4 quad stable with bit better cooling and if my mobo didn't have such a terrible vdrop (setting 1.525 in BIOS results in 1.47 and under load drops to 1.45-1.42 -_ - , will have to check on that ).
From my testing it looks like I can get any clock up to 4 - 4.2 stable as long as temps are under 50c (which obviously doesn't happen with my cooling, but hey, for this price I can't complain).
So instead of high clocks I aimed for maximum ht/nb which gives me similar performance, 3.7 with high HT is better than 4.0 with 2000ht.
