 - 8 Jan 2010
 - London
Hi currently using the asus dx with seinheisser hd 555, just wondering if I upgrade to the xonar essence if I would notice any difference in sound quality when listening to music.
			+1essence stx is a great sound card. Outstanding sound quality for a computer sound card.
Only thing you can do is up the gain. Next to headphones in the Xonar control panel is an icon, selecting it will allow you to choose a choice of 3 gain settings. Normal will be default, 0db gain in other words. Try the middle one 64db - 300db gain. This will provide more juice to your phones. They will be a lot louder, so you might want to lower the volume a bit before you do that. If that doesn't make any difference to the overall sound quality, then I don't think I would try the 300db - 600gb gain, you might damage something with that setting, as it is far higher than the HD555 ohm rating.
