Caporegime
- 12 Mar 2009
Is the conclusion then that windows 7 is as good as it's possible to get, with the exception of moving the paging file and user data to different hard drives to the OS?
Since windows supports an enormous variety of hardware out of the box, and is set up to do countless things which any given home user is not interested in, it seems implausible that it is not possible to change anything for the better. For example, vista came with an enormous quantity of drivers which do nothing other than eat hard drive space if you don't have the hardware they support, so it is reasonable to remove said drivers.
Is there nothing which by default will sit in ram doing nothing of any use, or processes which use cpu time but offer no benefit? Nothing which causes writes to hard drives which are not required?
I'm mainly an Apple user so I don't know too much about this compared to some people on these forums but I'd say that there are things which can be disabled, deleted or turned off but with todays probable average specs they don't really offer any noticeable benefit. IE. if someone has 4GB of RAM they aren't going to notice whether an MS Service that uses 2MB is running in the background or not. The same for un-needed drivers that ship with Windows. Windows 7 has all of that touch screen stuff iirc which most people here probably won't need but with the size and prices of hard drives nowadaways there's really no need to go to the effort of tinkering.
That's just my two pence.
