- 17 Jun 2009
- Swansea
Sorry for the rubbish design, i'm in work and on lunch using paint
. Below is the water loop i'm going to create, as this is my first loop i am only going to cool the cpu, i will eventually move on to GFX aswel.
System:
Rampage 2 extreme
i7 Do
5850
6GB DDR3 GT doms 1866Mhz (with cooling fan)
Case (just so you can suggest colour tubes etc):
TJ07
powder coated white (yes i've changed my mind again)
Purple neon's
white fan's
Water cooling kit:
Thermochill pa120.2
laing ddc 10w pump
Could you guys suggested a water cooling block, not keen on the D-tek (email in trust).
I'm prob gona get res:
EK Multioption RES 100 Rev2... aint bought it yet tho.
Here is my idea of setting up the flow, have i missed anything. Will the pump be strong enough to pump water fast enough thro the rad and in to the CPU as i figured its at its coolest temp coming out of the rad????.... or shall i put the rad ----> pump straight -----> in to the CPU?
I am also designing a middle casing plate to tidy the pipes up, what compression fittings can i use so instead of feeding tubes thro each whole they can fit straight into fittings on either side of the plate (if you get me)
What fittings could i use for the following:
Going to use distilled water with Silver Coil placed in top pump (Anti Algae)
. Below is the water loop i'm going to create, as this is my first loop i am only going to cool the cpu, i will eventually move on to GFX aswel.System:
Rampage 2 extreme
i7 Do
5850
TJ07
Purple neon's
white fan's
Water cooling kit:
Thermochill pa120.2
laing ddc 10w pump
