Low wattage... maybe 400w?
Everytime i had a psu blow out 9 times out of 10 it took the motherboard with it :/ (550w hiper was the last one to die)
Corsair HXs are Seasonics. TXs are Channel Well. Both good series. Not sure who does the CX and VX though, probably one of the 2 though, most likely seasonic aswell.
not all of them are.
The breakdown is this:
SeaSonic:
CX400W
VX450W
TX650W
HX450W
HX520W
HX620W
HX650W
CWT:
VX550W
TX750W
TX850W
TX950W
HX750W
HX850W
HX1000W
Or in short, SeaSonic makes everything up to 650W except for the VX550W, and CWT makes everything 750W and up, plus the VX550W.
Enermax warranty, last I checked, is 3-years. So OP should contact them for a RMA.You only had your enermax for a year? Are you going to rma it?
