Caporegime
- 13 May 2003
- Warwickshire
Hi all
I was running an evaluation copy of Windows 7 that expires at the end of the month. Today my retail copy of W7 Home Premium arrived, so I backed everything up, restarted the PC, deleted the RAID 0 array, and inserted the DVD.
I've set the boot priority to look for the DVD first and ignore all other sources, yet it still gives me a message: 'Missing operating system', after which, nothing further happens until I ctrl-alt-del.
Can anyone give me some ideas as to how I can get around this or what the problem might be?
It's definitely an official retail copy of W7 (purchased from a major online retailer) and I've definitely set the boot sequence to look for the DVD drive first.
I've already deleted the RAID array so I can't go back into the OS to intall from there, and in any case I've tried booting from my old Vista and XP discs with no luck.
Thanks
P.S. I've tried pressing F12 to manually select the optical drive with no luck. The disc definitely works as I've put it in the laptop and I can read the disc and all the files.
Thanks
.P.S. I've tried pressing F12 to manually select the optical drive with no luck. The disc definitely works as I've put it in the laptop and I can read the disc and all the files.
I've tried two other discs that have been booted from on previous occasions on the same computer.
