THIS WEEK ONLY 17/02/2010
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
We have 17 new deals THIS WEEK ONLY. Some of the highlights include:-
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.20GHz Max / Asus Rampage II Extreme Intel X58 Motherboard / Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz DDR3 Bundle @ £739.99 inc VAT
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast. Available with three different levels of overclock your ideal bundle is just one option away.
This is our fastest bundle to date! We take full advantage of the Asus Rampage II Extreme capabilities by pushing the chip to its limits, ensuring you have the fastest hardware on the planet.
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz overclocked up to 4.20GHz!
1 X Asus Rampage II Extreme Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
1 X Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9)
1 X Prolimatech Megahalems Performance CPU Cooler (Socket 775/1366)
1 X Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM
1 X Arctic Cooling MX-2 Thermal Compound
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours.
Note - The Rampage II Extreme motherboard is one of the largest available and will overhang the last risers on your motherboard tray, please ensure you have enough room in your case before ordering.
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced.
Note - The bundle operates above manufacturer specifications, as such it requires a quality power supply to operate with guaranteed stability. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range.
Note - Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £739.99 inc VAT.
ORDER NOW
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-12800 1600MHz Dual Channel + 3D Mark Vantage (PVV34G1600LLKB) @ £76.99 inc VAT
The Patriot Viper II 'Sector 5' Series, part of the Extreme Performance (EP) line, is the ultimate performance memory solution for the Intel®P55 system platform. The Viper II 'Sector 5' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the P55 platform to achieve optimized performance and maximum quality. These modules are engineered to reach 1600MHz at 7-7-7-20 timings and are available in 4GB kit capacity. This kit includes Futuremark's®3DMark®Vantage benchmarking software for enthusiasts to fine tune their system for optimal performance.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (7-7-7-20)
- XMP Ready
- Equipped with advance aluminum heat-dispersing shields
- 100% Tested and Verified
- Lifetime Warranty
- RoHS Compliant
- Tested on Intel®P55 chipset
Only £76.99 inc VAT.
ORDER NOW
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply @ £59.98 inc VAT
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- up to 86% Efficiency
- Overvoltage/OverPower/Short-Circuit protection
- (.99)Active PFC
- MTBF: 100,000 hours @ 25C
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
Only £59.98 inc VAT.
ORDER NOW
Patriot PS-100 32GB 2.5" SATA-II Solid State Hard Drive @ £64.99 inc VAT
The Patriot PS-100 SSD is a great way to upgrade an existing desktop or notebook computer. The PS-100 drive brings faster boot and application load times, reduced power consumption and improved durability. Looking to extend the length of your notebook’s battery? The PS-100 significantly reduces power draw extending battery life and reducing heat. PS-100 drives are more durable than traditional hard drives and are ready for the rough and tumble world of every day computing. What’s more, they are silent.
- Capacity: 32GB
- Cache: 64MB
- Read: Up to 210MB/sec
- Write: Up to 150MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- Low Power Consumption
- Lightweight (75g)
- Shock Resistant
- Warranty: 3 Years
Only £64.99 inc VAT.
ORDER NOW
We have 17 new deals today THIS WEEK ONLY
Are those Patriot SSD's still dog ****? or have they have new (actually working) firmware yet?
Hmmm, this week sucks compared to normal :( :o
Only decent thing imo is the OCZ PSU and the SSD (which might be a pile of crap XD)
Thank you for your feedback, remember the 4 items at the top are only a very small selection of the products we have this week.
Surely there is something from the whole range you like?
Phil
glad i ordered last week, would have cost meh £9 more this week, mind you as the order was £1644 its neither here nor there lol
btw you still expecting my ocz LE SSD to be arriving with you this friday?
EDIT: didnt see the i7 had gone up so much, so thats actually a £15 saving
if the PSU was a Corsair HX7/850 or a more reliable SSD :D
I work on festival park so I could just sneak off work a little earlier ;)
Order just placed for the PSU.
Do OCZ make quality power supplies? My previous ones were always Seasonic or Corsair.
Edit/ And more importantly will it fit in a Lian Li V351. Should have checked before I pressed buy. :eek:
OCZ are still saying that should be the case. Hopefully they'll deliver on their promise.
OCZ PSUs are incredibly popular due to excellent value for money and good reliability. If products are unreliable then things generally spread around the internet like wildfire.
still waiting on the samsung 120hz monitor to go in the weeklys for weeks now :(
Samsung are possibly due some price increases in March, not drops. :(
nothing for me this week from the offers, but can guarantee you the asus soundcards will be on offer next week as I just placed an order for one and it always happens when ever I buy something lol
Have been using a OCZ GameXstream for years and had no problems, plenty of cabling and looks good :)
its nice to have any money off any item but is it really
"substantially reduced in price " ?
£5 on psu is good, but no really "OMG i got to buy". Nethertheless i am ordering this evening lol. (full system).
The OCZ PSU's really do perform well, and compared to other leading brands the pricing is very good.
PS-100 still awaiting Trim support. That seems to be the only major gripe about them on boards
[ZiiP]carrot;15981130 said:
Ace, any info on those PS-100, any one at OCUK HQ using one and wanna shed some light on what they are like in terms of a boot drive??
Indeed.
I want to get Win7 and want to know how these will perform as an OS drive?
