- 4 Nov 2006
- Yorkshire
Would using a treadmill for say 20-30 mins a day be bad for the knees, as oppose to jogging outside on a range of terrains/inclines/conditions etc?
Also, try running without shoes, so you don't hit your heal first before the balls of your feet. Hitting down with your heals is apparently the same as hitting them with a sledgehammer, or so I read.![]()
Unless you have a pre-existing knee condition - no, running is not bad for the knees. I don't know where people get this tripe from. Running on a treadmill is a great way to start running whilst you build up leg strength. I would avoid running off road if you are just starting out. I made that mistake.
Hope this doesn't class as a medical post but where did you get you knees checked out? Was your first port of call your GP or straight elsewhere i.e physo, etc?
Absolute garbage. I find it hard to believe that given the amount of running you claim to have done, you can't tell the difference between running on a treadmill and road running.10k on a road or 10k on a treadmill is still 10k running except it's less damaging.
Road running is ruthless because there is no give where a well cushioned treadmill makes things easier.
I absolutely know 100% that when I get back out on the road it will be harder.
Can you read all my post please before you go spouting off.
It is so infuriating that people read a little bit and then quote on it.
Somebody has just done it in another thread.
I'll give you a clue since you can't be bothered to read -
Apologise anytime you feel like it.
