G92 renamed again?
Hmm dunno if they just missed the .1 but it doesn't seem to be based on the DX10.1 40nm process like the GT340... which could indicated a G92 rename but I'd have thought it would be the new process.
probably a 40nm respin.
think that caught my eye is that it can apparently have "96-112" cores. sounds like there may be two chips or some cores getting chopped off here...
I don't think its even a respin... well spotted.
Look like a 55nm G92b core.
The GT320 and 340 are indeed 40nm DX10.1 cores... guess this is why nVidia moved GF100 to the 4 series (it would have been the 4 series originally if the 212 cores had come out when they were supposed to).
To be fair I have one in my laptop under the guise of a GTX260m and at 1680x very little troubles it on max settings - still pumping out decent fps...
The only downside for me is that their naming scheme started making some sense again, with G2xx cards being DX10 and G3xx cards being DX10.1 and G4xx being DX11 however this card kind of throws this theory out of the window.
Shame
Shame
You do realise the dx10.1 cards were launched as g2XX parts, then renamed, and the mobile 3XX parts were already a mix of 55nm G92 parts, and the new 40nm dx10.1 parts. They disabled the dx10.1 on the mobile parts so as not to confuse everyone.
Then they've gone and added new 3XX parts without dx10 anyway, its a cluster **** basically. Even from what I recall that the GT330 can have a higher bus and more shaders than a GT340, just without the gddr5 and dx10.1. There will probably be some gt330's that are faster than gt340's.
Seems quite a small card... The fact it uses DDR3 instead of GDDR3 throws it a bit though because I didn't think that the 9600/9800GT cards had that capability.
I thought it looked a bit too small and the PCB looked too basic to house a G92 GPU.
It also says 256-bit, 192-bit, 128-bit. That isn't very specific. I think someone at Nvidia has put it up without finishing it.
Also, the GT240 has 96SP's. This may be a derivative of that.
