If it doesn't work, return it as faulty.Found a Ivuna Advanced High Speed 15m HDMI Cable for £37. Is that gonna be ok or is a magic fairy dust ££££ one needed?
ironically, you are wrong. it makes naff all difference how big the screen is. it's how big each pixel appears and for that it doesnt matter if your watching a 1080p 20" screen from a distance of 20 inches, or a 100@ screen from 15 feet....you'd still see a huge difference.
1: Blu-ray (1080p) is much better quality that DVD but is most noticeable on larger sized screens typically 40" +.
Found a Ivuna Advanced High Speed 15m HDMI Cable for £37. Is that gonna be ok or is a magic fairy dust ££££ one needed? Or is Cat5/6 extenders the only option?
I ran a 15m dvi->hdmi, picture was fine, £14 from ebay![]()
Stockhausen is just a muppet, ignore him.
Hmm, sounds good. Full 1080p (or higher) res?
ironically, you are wrong etc
Indeed, My TV is 32", And HD movies are miles better than DVD, To say otherwise is silly. Jaybee refer to the pictures in this thread. Why would a smaller screen mean that quality difference would be any narrower?
That was taken sat approx 7 foot away from the screen and at 50mm which is (give or take) the zoom level of the human eye.
Comparisons.
It's simple. A digital cable sends a 1 or an 0. That's it. If you want to spend £90 on a cable to do that, you need to have a block of wood with rusty nails hammered up your backside.
Your take-away from all this should be the following:
* At lengths less than 4 meters you can just about use silly string (OK, not really) and get HDMI to pass at any current resolution. At less than 3 meters you'll even extend that to 12-bit color and possibly the next crazy idea HDMI Licensing decides to throw at consumers. Don't spend a lot on these cables and if you want to save money you won't let anyone at a big box store talk you into buying from them.
* At long lengths (over 10 meters) you really need to pay attention to the manufacturer if you don't want to risk running into potential problems with 1080p and future formats such as Deep Color. With that said, just about any cable at or under 10 meters will pass 720p/1080i and nearly everyone will pass 1080p at 8-bit color as well.
What is "VHS"?!
or at least wouldn't notice enough to justify the cost.
