so if i sat 10metres away form a 50" screen, i'd see more detail than i would at half a foot from a 24" screen? thats a bit silly but it fits the example - it really does not matter how big the screen is. The reason why people say it's easier to see it on bigger screens is because they sit there and replace their 32" with a 40". now they're sitting the same distance from a screen thats 8" bigger - of course it's easier to see lol. However, if they had sit closer to that 32" screen......then they would have seen the same increase in definition
yeah, you'd think so.
it is not the tv size, its the relative size of the pixels as they appear to you. are you lot just assuming you see more detail on a big screen, because that isnt true.
you have 2,073,600 pixels, yes? will a 20" 1080p monitor fail to render all those pixels? nope. take a 65" 1080p screen - same amount of pixels. There is a certain distance where the pixels on each screen will appear to be exact
*as you see it* so which one is going to show you more details? in a perfect world, 20/20 vision....neither of them.
where i sit, in relation to my 50" screen and my 24" monitor, means that the screen appear roughly the same size to me. my 24" DGM reveals just as much "detail" as my 50" except where a plasma will obviously win over a budget LCD- black details and so on, but thats not a function of screen size at all.
...The point is kyle, screen size is not important.
of course it isnt, screen size is fixed, unless you cheat and use a projector
. how big it appears to you is what's important and that's what i said, which you argued with
