Just run Ethernet from your modem/router to wherever you need to, less likely to give you any grief.
There are two mistakes in that sentence. The first is using AOL as an ISP.AOL told me that RJ11 isn't really much good over 15-20m.
Use Cat5e and put a secondary hardwired telephone socket in your room. Will give you next to no loss on the cable as well. And Would be easier to fit.
I do agree that AOL can be a bit annoying.
I think i'm getting abit confused now lol
If i got a cat5e cable and plugged it into the micro filter at the front door and then led it upto my bedroom and plugged the other end of the cat5e cable into the adsl line port on my router, would this work?
