Only 3.87GB usable on Gigabyte H55-UD3H
28 Dec 2003
Ok so I've just put together a system based around the above motherboard with a Core i3 and 2 x 2GB of OCZ memory.
For some reason I don't have the full 4GB available. Windows 7 reports "4.00GB (3.87GB usable) and the BIOS itself reports the installed memory as 4096MB but the "total" memory as 3968MB.
Now my first thought was that some memory was being taken for the on-package graphics on the i3 but I'm not using this and the motherboard is set to disable the on-package graphics if a separate card is installed. I can't see any separate setting for memory "allocated" to the on-package graphics.
Anyone got any ideas?
Not tried that but figured that, since the BIOS was showing 4096MB installed, it was unlikely the DIMMs were faulty. 128MB does look very much like the amount it would take for on-board graphics tbh.
I will try the DIMMs separately tomorrow to see if that makes any difference but my money's still on it being taken for graphics. I reckon they've put an option in the BIOS to disable the on-package graphics but it's still reserving the memory. Have raised a support issue with Gigabyte.
Ok this gets weirder and weirder.
Tried each of the DIMMs by themselves and, in each case, the reported memory is 1984MB, i.e. 64MB missing from each one!
Hmm, are you sure there is not a setting hidden in the bios somewhere for the shared video memory? it might be under the CPU settings seeing as its integrated into it.
run msconfig and then go into boot and the advanced option, in there you should see on the top right maximum memory, make sure thats unselected. if it is already selected that could be your problem
Don't these i3's have onboard GPUs?
It will more than likely be a setting in the BIOS that you can select to assign some RAM to that.
A similar thing happens with an old AM2 mobo I had with onboard graphics.
If you have a graphics card connected and are not using the GPU that's on the processor, then you just need to change the BIOS setting for assigning RAM to the onboard graphics to auto or disabled if your BIOS allows it and make sure the onboard graphics is disabled, that way it doesn't alocate any RAM to the onboard GPU.
This definitely sounds like the problem mate, 64GB is being assigned to the onboard GPU in the processor.
