best memory for my system?
Man of Honour
9 Jan 2010
hi, im in the final stages of building my gaming system but im stuck as to what memory would work best with it. i know i want 6Gb tri channel but i dunno what speed/spec/make would be best, my system is all at stock clock speeds atm but i want this system to last me for ~5 years so il probably O'C at some point.
you can see my system in my sig... what memory would suit it the best?
thanks for any help
If you can't use ram with tall heatsinks it's very good, otherwise the viper or the tridents if you want to spend bit more.
Go with the normal sized corsair. I seem to remember the ripjaws are pretty low, check the noctua site for ram comparability.
do you think this will be ok? or maybe 2000mhz would compliment my system better? sorry but im realy noob with RAM :( (and a little drunk atm) :p
im not too fussed about price but i dont wanna get somthing thats way ahead of the rest of my system (see sig)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-188-CS&groupid=701&catid=8&subcat=1389
