AND AGAIN....
OK I'm annoyed...
Using Automatic settings... which is basically HIGH settings except HDR, Volumetric Effects and Distortion Effects are OFF but with AA disabled and AF as trilinear.
I went into a few battles and it was fine. But each battle and reload/return to the map dropped a few FPS (On to something here?). I didn't touch the settings when I noticed this. I went into a battle, and accidently highlighted everyone and pressed CTRL+W lol (done that twice now
) and retreated everyone, but on return to that battle by loading the game again to the Campaign map, the FPS had dropped from about 50 to 30. I went out of the battle and reloaded to the Campaign map and retried the very same battle for the 3rd time! The FPS had dropped from 30 to 18fps. Note that this was in the deployment phase, when characters are idle and hardly anything is going on.
Considering how I could play on Ultra with all effects on except hardware shadows and SSAO, then there is some sort of "Leak" going on here... I think the dips in FPS per battle is a clear sign of this. Something is keeping something in cache/memory and then going into another battle is keeping more stuff loaded in there, and so on so forth until FPS dips and dips. I'm happy playing with no effects on and running everything on high, but with it dipping to low FPS ranges dependant on the number of battles then that is clearly unacceptable.
I was playing these games at 1680x1050 native (60Hz). I am using Windows 7 Home Premium 64 just to refresh your minds. I have 4GB of Corsair Dominator 1600Mhz DDR3, I have a 1GB XFX Radeon HD 4870 GDDR5, I have a 1010w Modular FSP PSU and I have a Stock Clocked AMD Phenom II X4 955 Black Edition 3.2Ghz Quad Core (AM3) running at approx 40 degrees under load whilst in the game for a while. My motherboard is a ASUS Crosshair III Formula iRoG.
I know there is to be another patch for this game because I read up on it before the game had arrived in the post, but there needs to be some sort of optimization patch. I hope Napoleon doesn't result in the crappy half-arsed AI grouping patch to be the last one.
First Creative Assembly game I've had and so far, I am not impressed.
Apologies for any typos, I am tired.
