I wasn't going to bother with a log on this as it's just a quick and dirty temporary job until I get the cabinet for the HTPC that I built. However - given how ridiculous it looks I thought I'd share the comedy...
I started with a 2U box that I had lying around, I didn't get any pre-mod shots, but you get the idea from this shot - that massive hole in the top is obviously new!
Into that box I was going to squeeze my HTPC:
Phenom 7750
ASUS M3A78-EM
4Gb Ram
2.5" Laptop HDD
PicoITX-150-XT PSU (awesome bit of kit) + Powerbrick
Compro S350 DVB-S (Forgot about this one initially - oh how I laughed after installing everything and realising that not only was it NOT low-profile - but there was no slot in the case for it
And of course - no SFF build is complete without a quiet, compact, unobtrusive HSF... I went for the Thermalright IFX-14
I had to try and fit all of this......
Fit into the little box...
Anyway - I got the jigsaw out and made a few minor modifications to the Box and ended up with this:
Then I remembered the Compro
Did a bit more chopping and ended up with the nearly finished article:
and
Against all the odds, it turned on first time and seems to have survived the butchering! I then remembered that I need to be able to switch it on - so I stole an On/Off, Reset, LED group from an old case I had lying around and presto! Now I just need to find a permanent way of attaching them to the case and I'm done. This was just going to be a stop-gap until my cabinet arrived (that's now a matter for the small claims court
) - so it looks like this will be with us for a while - so I might spend some time tarting it up - suggestions welcome!
Phenom 7750
ASUS M3A78-EM
4Gb Ram
2.5" Laptop HDD
and
