Well following on from Easy Riders superb effort at a cinema room. I'm also going to be having a go.
Very kind,
Good luck mate and I will follow with interest.
2) Speakers, to get decent sound in the room I'd like a decent speaker set up. I've seen some nice Kef 1005.2's for £299. They seem to have great reviews, can anyone comment on personal expereince of these, or provide another option in the same price range. I want small speakers and be able to mount them on the wall preferrably.
Thanks
Taff
I can vouch for that Markus chair, my friend has one and it's awesome.
I probs won't get to measure his chair for a while to be honest, but for what it's worth I have this chair which has a max height of 50cm, and when measured it comes to around 54cm. http://www.ikea.com/us/en/catalog/products/70133761
For the Markus, I reckon you'd be able to put spacers between the casters and the chair frame as you put them on yourself. Might be able to get casters with an even longer axle to allow you to raise it further.
One think, your desk (if that's the one you're using), doesn't look much taller than mine and at the max height it's, if anything, too heigh for the desk.
For reference, my desk is 70cm tall approx.
first thing I have noticed it is that the door surely must be hung the other way around. how do you even get into the room with the sofa there!?!?!?
even without the sofa, it would be a strange way to put the door on.
