Mac OS X is Unix - with the unique selling point of a good GUI instead of an awful one.If you want programming or other fancy things, you probably want Unix.
Things OS X Cannot Do
Right Click to Create Text Files: You have to open TextEdit, create a file, navigate to the right folder, and save as…just to create a stupid file.
Set a picture as background: You certainly cannot select a picture in finder to set it as background. No app in OS X lets you do that. You have to use go through a long series of clicks in desktop background settings and manually find your file. The only other way is to open your image file in firefox and set as background, but having to open a a image from a browser to set it as background is lame.
Choose entire folders to be wallpapers: You can add a folder, but SUBFOLDERS ARE NOT INCLUDED. That means you can’t manually organize your wallpapesr. Again, iPhoto is useless for anything but photos, so unless all your wallpapers are photos, don’t expect iPhoto to be a solution.
Merging folders: (See a comment below for why you need to do this) When you copy a folder, if the new location contains a folder of the same name, there is no way to merge the folders. Instead, Finder overwrites the original folder with the new one. All files in the original folder are lost. The only way to get around this is to use the unix mv -v command….very user unfriendly design.
Cannot selectively delete trash: There is no way to delete one or several items in trash at a time. (useful when you want to double check the items one at a time before you actually delete them). You can only empty all the trash at once.
Cannot restore trash: If you accidentally moved something to trash by accident, there is no option to restore the file to its original location. You have to remember where it was. Why do you even need trash if you can’t even restore what you deleted to where it was? If you accidentally deleted a file buried deep in the filesystem, does it make sense to drag it back to….for example…Desktop??
There is no cut: There is no "cut" option like in all other OS. So to move a file you have navigate to the destination in a separate Finder window and drag to it, or drag while navigating in the same Finder window through many folders and hope you don’t miss.
Can’t calculate total size: When you select some files in a folder and right click -> Get Info to find the total size, Finder displays a box for EACH item with the individual sizes.
Things OSX 10.5 cannot do:
As for the text file bit, you just right click > new > text file then open it and add your text or whatever content then close the window saving changes. Easy.
Some of those aren't silly things to have anyway, total filesize of a bunch of selected files is pretty important for a start.
Oh okay!
The underdog?
They oversized the iPhone and called it the iPad for god's sake![]()
The underdog?
The underdog?
. . . or Lotus, Ashton-Tate, VisiCorp and Digital Research?I think that is where Microsoft's strength lies in office applications, they are **** at Operating Systems. MS Word, MS Excel. I just wonder if they will go the way of WordPerfect and WordStar in a few years time.
Now I KNOW you are having a laugh... Also MS offer the security and support with their product ...
